Wall Mount Motorised Bracket for Avant 55
Markijan
Sydney
Posts 1
Markijan Posted: Sat, Sep 5 2020 2:01 PM
Dear 'B&O" Brainstrust........
I have an Avant55 with a motorised wall bracket configured to open toward the left. I have had to relocate the tv to another wall that will require right opening trajectory. Can anyone provide me info on whether these brackets are side specific or if the bracket can be modified to reverse the original opening path.
Cheers and thanks in advance.
Markijan
Beozip
Posts 368
Beozip replied on Sun, Sep 6 2020 11:45 AM
these motorised wall bracket are side specific. One for the left and one for the right side.
An alternate is the STB Gyro for the Avant. You can use it for two sides.
https://www.stbbrackets.co.uk/de/produkt/beovision-avant-55/beovision-avant-55-gyro-avant
I use it with my BV Eclipse and  I am very happy with this.
Page 1 of 1 (2 items) | RSS
