I know the set up manual says "avoid placing the stereo in direct sunlight" but is there any way to modify the sensors or sth else?
I've 2 Ouvertures and they keep opening their doors as soon as the sun fetches them. Sometimes they close for some seconds when clouds are passing by until they open again.
Usually I pull the plug or close the curtains in the room, same procedure every day...
