Hi BeoWorld,
I could not find anything on-line about this subject.
I just got my hands on an AV7000. I currently have my Penta 1’s hooked up to a Beomaster 5500 (I just purchased a Beomaster 7000 as well) but would like to add the surround processor to add rear speakers and a center channel. I forgot my Penta only have the 4 pin connector and not the newer one that is either 8 or 9 pins round one. Is there a converter to make them compatible?
Also, side questions... for the Penta’s, is there a way to disable the display? I like it showing on one speaker but find it distracting with it is showing on both and it isn’t needed.
Thanks BeoWorld!!!! Glad I found these forums.
You probably already know the answers by now but just in case:
For the display issue: use a full mounted powerlink cable for the one you want the display to show, and just a half mounted powerlink cable for the other one.
