Does WISA allows to get rid of a Beovision
mbee
Paris, France
Posts 1,842
mbee Posted: Tue, Sep 29 2020 8:58 AM
Let’s speak about interior design : I like to have a small TV or a total absence of TV in my living room. Currently, I have a Beovision 8-40 and a motorised screen with a projector for when I need a cinema experience (sound is 5.1, Beolab 3 front, beolab 4000 rear and beolab 19 to add a bit of sensations).
I consider upgrading to a Beovision Harmony 65 (with a new 4K projector to be defined later), but I’m not completely decided and the price increases put me a bit away of it. Note that the harmony 65 seems to show less black screen space when turned off than my bv8-40!
looking at projectors, I’ve seen that LG will soon release the HU810P, which has a full WebOS inside and wisa... so I had an idea : why not upgrade my 5.1 (or 5.0 as the BL19 is already WISA-ready) to Wisa and get rid of the TV (the projector being laser-based, I’ll not suffer of low lamp lifetime, and brightness should be sufficient for daily use).
so... is a LG wisa source (hello LG 65C9/CX owners!) sufficient to drive a 5.1 B&O setup or I am missing something??
Millemissen
Flensborg, Denmark
Posts 14,680
The WiSA function of the LG’s is very rudimentary (compared to what you have in a B&O-tv).
All I can say is, that I have heard noone, who has tried this, speak positive/enthusiastic about it.
By the way - if you get a Harmony 65” you maybe won’t need the projector solution at all.....of course depending on the size of your room.
mbee
Paris, France
Posts 1,842
mbee replied on Tue, Sep 29 2020 9:19 PM
Ok, thank you.
Concerning getting rid of the projector, I think I’m not ready for that : I currently project with a 2,50m wide image, a 65 inch tv will never be immersive enough, whatever the picture quality (oled) may be...
Page 1 of 1 (3 items) | RSS
