Hi
I have been gifted with a 6-26 on Motorstand.
It has ATV with PUC control connected via DVI and SPDIF>RCA.
All good.
But it does not react on Radio commands. It has no Radio aerial socket but the service menu does define it as BC6-26. And the sticker behind the speaker cover says: BeoCenter 6-26, Type 9280
Did B&O produce and label this TV as BeoCenter without adding the Radio module ?
Weird !
Regards
Ravsted
Ravsted:Did B&O produce and label this TV as BeoCenter without adding the Radio module ?
Yes - I have a BC6-26 Type 9282 that has no radio.
It states on Beoworld that the FM radio was only standard on the BC6-23 (and it is indeed included on mine): https://www.beoworld.org/prod_details.asp?pid=741
Ravsted:But it does not react on Radio commands.
Try to go into Menu > Option > Beolink and select "Internal radio".
I see...
I thought FM was standard on any BC and DAB was optional. If no Radio why not call it BeoVision ?
In the option menu I have: Connections, Sound, Picture, Date/Time and Language.
No menu called Beolink and Radio.
It does however have masterlink.
Never the less... Got it clarified. Thank you for your answers. I managed to get the ATV and audio converter into the little cable compartment on the back of the TV.
The aluminium speaker cover was in bad shape. But I managed to add black speaker frett to it.
So, pretty happy with this little, cute TV.
Ravsted: No menu called Beolink and Radio.
Then maybe no Radio Option as Guy said.
