Could be one or more bad capacitors in the power supply or a bad rectifier.A bad output hybrid IC can also cause this.
Ironically I have precisely the same issue, fortunately I have a Beomaster 3300 in reserve, I will get it serviced though. :)
Thanks for the information Dillen.
