Essence Un Integration problem
Razlaw
Posts 4,345
Razlaw Posted: Sun, Oct 4 2020 3:31 AM
I was curious about the integration feature in the app so I integrated my Essence with my V1. I would now like to un integrate. I have changed the settings in the app so it is not integrated. I have deleted and reinstalled the app on my phone, not my iPad, yet. I have rebooted and reset the Essence through the app. I have reset the Essence using the reset on the Essence itself. I have removed it from power. Have repeatedly uninstalled and reinstalled the Essence. All goes fine but then the app says as Essence was previously integrated, it will not be displayed in the app, and the Essence image/option disappears.
Any suggestions how to get it to fully un integrate? Thanks!
Razlaw
Posts 4,345
Razlaw replied on Sun, Oct 4 2020 4:20 AM
If I select V1 in the app, it still shows it as integrated. It is not showing that in the on screen menu. Deleted C1 from the app. Essence appeared. Added V1 back in to app and Essence disappeared again as integrated.
Razlaw
Posts 4,345
Razlaw replied on Sun, Oct 4 2020 4:26 AM
Solved. After deselecting the Essence in the V1 menu, apparently I neglected to press the green button on the Beo 4 to save the deselection.
Millemissen
Flensborg, Denmark
Posts 14,680
Oh well, I have done that several times myself (earlier)....wondering why the damn thing did not work!
As long as you learn from you mistakes, it’s allright.
By the way, why did you want to un-integrate it?
Razlaw
Posts 4,345
Razlaw replied on Sun, Oct 4 2020 1:28 PM
I was just experimenting. Essence and V1 are in two different rooms. With them integrated I could control the 9s connected to the V1 with the Halo. But I lost control of the 4000s connected directly to the Essence.
Millemissen
Flensborg, Denmark
Posts 14,680
Razlaw:
Okay - by the way....I like that - keep on experimenting, best way to learn.
Razlaw
Posts 4,345
Razlaw replied on Sun, Oct 4 2020 4:19 PM
Will have to get another Core I guess if I want to control the 9s with the Halo.
Page 1 of 1 (7 items) | RSS
