I have been having a devil of a time getting the Chromecast built-in function to work on my Beoplay A6. I’ve been back-and-forth with Support for a very long time and they have eventually advised me simply to use airplay 2. I cannot stream with my iPhone into Chromecast at all and my laptop only works intermittently with poor sound quality. I have reset the unit several times and have had no success. I enjoy using the chrome cast function and have now purchased a Chromecast audio dongle. Do you think it will work in the 3.5 mm Jack on the rear (bottom) of the basics? Any compatibility issues?
That's very odd -- I have a BeoPlay A6 that is used almost exclusively with Chromecast.
Perhaps it is a network connectivity issue? Mine is sitting right next to a mesh router, so gets a wired connection which has been flawless. You could try running a wire across the floor to your router to see if it works better in wired configuration.
The Chromecast Audio dongle will likely work, but then you have two different volume controls, which is always a hassle.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
Thanks for the quick reply. The unit is hard wired directly to the mesh router (Eero Pro) and Airplay 2 works flawlessly. Can’t figure it out; if I power cycle, occasionally it works. Love Chromecast, want the functionality.
Unfortunately, no. I don’t think that they’ve made the A6 for a very long time. I actually had wanted to buy a second one and couldn’t find one. (At least from the dealer.) I found a Chromecast audio online on eBay and I should get it in a few days. I will give it a try. If it works, I will get the functionality that the unit should have had in the first place and will be much more convenient in my office.
