Hi
I wanted to buy a MX7000 with motorized stand, the seller told me it worked. The day of pickup, he told me that the TV doesn't turn up anymore. So he gifted me instead of throwing it away.
I have some questions:
- Can I take the motorized stand and install it on my other MX7000 ? Is there any guide somewhere ?
- I own a second MX7000 so I can eventually exchange the different PCB until I find the faulty one, then I can try to fix it. Good or bad any ? Is there any risk to damage the PCB if the problem is located somewhere else ?
- What should I check first (fuses, etc.) ?
Thank you
