Beosound3000 CD Player
This post has 1 Reply | 2 Followers
gpw1
Posts 2
gpw1 Posted: Mon, Nov 19 2012 11:38 PM
Hi
My 3000s CD player is playing up.It will run fine for upto 6 tracks from turning unit on,then it will start to make a noise like its struggling to read the disc and keeps cutting off..
Any idea's?
Many thanks in advance.
kokomo
Spain
Posts 206
kokomo replied on Tue, Nov 20 2012 10:47 AM
The 'experts' will I'm sure give you the best advice, but it sounds to me like the mechanism which transports the laser across the disc is getting stuck along its route. Might be just dirt/dust  which can be easily cleaned or perhaps try applying one of the specialist electrical lubricant/cleaner sprays to the transport mechanism.
Page 1 of 1 (2 items) | RSS
