Question beovision 8-26, I have virgin v6 box going round the one of the freeview channels and works fine on the other bang and olufsen tvs. However on the bvis 8-26, i have perfect sound but no picture, tv has has been updated to latest software and the freeview module has been upgraded. Has anyone has this issue?
Hi, thanks for the reply I never thought of that will give it a try
I had the software updated and changed the resolution to 720p, still no picture but perfect sound, all the other tv are working, I have put a cheap freeview box in and I get sound and picture, worst case i can put this in back of tv, any ideas why built in freeview wont work, both software on tv and freeviee have been updated
kai:I had the software updated and changed the resolution to 720p
kai:I have put a cheap freeview box in and I get sound and picture
kai:any ideas why built in freeview wont work, both software on tv and freeviee have been updated
Hi in answer to your question
Tv has been updated to latest software as has the freeview module. I don't use the hdmi as freeview is internal which i select with dtv, freeview is working. We have an hdmi modulator that is connected to the virgin, which allows me to tune in virgin to the freeview, this works on all tvs except the bvis 8-26. I can get sound but no picture. I did try and put the resolution down to 720p on virgin box but same issue
Hey thanks for the reply, it simply allows yoirnto distribute hdmi via a freeview channel, i seeing it allows 720p output failing that thits freeview box on the back of the tv
