Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Can I add - stop making things daft shapes that add nothing just because you can.
Ban boring signatures!
My experience has just been the opposite. In the last couple of years, B&O’s hardware and software quality has improved quite a bit - the B&O App is a good example. it is easy to see the ‘other side of the fence is greener’. I have owned Naim and Focal products and they are no better or worse when it comes to quality and support. My current H95 headphones replaced a Focal headphone and the A9 replaced a Naim speaker.
My 2 cents is that B&O needs to cut back a few of their products to focus better. B&O to me has always been about design, lifestyle and audio - all together. They are not perfect, but I do enjoy their products. Building something in China does not make it poor quality. In many cases, Chinese products are at the same or even superior to what comes out of Europe or US.
B&O in my life 😊:
Eclipse 65V1-32Beosound M5Essence MK2BLI
Puncher:Can I add - stop making things daft shapes that add nothing just because you can. Ban boring signatures!
Jaffrey2230:My experience has just been the opposite. In the last couple of years, B&O’s hardware and software quality has improved quite a bit - the B&O App is a good example. it is easy to see the ‘other side of the fence is greener’. I have owned Naim and Focal products and they are no better or worse when it comes to quality and support. My current H95 headphones replaced a Focal headphone and the A9 replaced a Naim speaker. My 2 cents is that B&O needs to cut back a few of their products to focus better. B&O to me has always been about design, lifestyle and audio - all together. They are not perfect, but I do enjoy their products. Building something in China does not make it poor quality. In many cases, Chinese products are at the same or even superior to what comes out of Europe or US. My B&O Home: Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office) Beolab 6000 + Beolab 11 + Beosound Core (Bedroom) Beoplay A9 Mk2 (Living Room) Beosound 1 with wireless dock (Portable) Beoplay M5 (Dining) Beoplay H95 (Focused listening, travel) Beoplay H9 (3rd gen) (retired) Beoplay P6 (Portable) Beotime wall clock (hallway entrance) Beoremote X (poor man's Halo )
Sandyb: The Edge being a case in point - very pleasant looking design, but its proper use case is very limited. As evidenced by its lack of success / impact.
I own an Edge....and barely use it. There aren't many places you can use it, the bass is just ridiculous. And the sound is very odd. The cheaper BeoSound 2 (of which I have two pairs) is a better speaker.
I disagree about integration. I don't need it anymore personally. I love controlling my new B&O speakers with voice. I just think a lot of the older generation don't want to go near this with the fear of learning something completely different, so want control via their remote. Voice control is far better and far more convenient for me.
I can walk around my apartment effectively talking to my various devices. No need for remotes, no need for 'integration' and no need to go back to 1994.
Barry Santini:This is my message to B&O management: Not product lifetime support. But a pledge to open the ecosystem innards to others to correct or carry on the legacy.
My experience with the B&O App with the products I have had been pretty good and solid. FWIW, I had a couple of older BeoLab products and once I connected them to a BS Core abs set the speaker settings in the App, the sound quality was noticeably better. So in a way, B&O has supported their product for me for 15 years now! Any product from any other brand would have been retired by now.
My 2 cents worth.
Jaffrey2230:My experience with the B&O App with the products I have had been pretty good and solid. FWIW, I had a couple of older BeoLab products and once I connected them to a BS Core abs set the speaker settings in the App, the sound quality was noticeably better. So in a way, B&O has supported their product for me for 15 years now! Any product from any other brand would have been retired by now. My 2 cents worth. My B&O Home: Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office) Beolab 6000 + Beolab 11 + Beosound Core (Bedroom) Beoplay A9 Mk2 (Living Room) Beosound 1 with wireless dock (Portable) Beoplay M5 (Dining) Beoplay H95 (Focused listening, travel) Beoplay H9 (3rd gen) (retired) Beoplay P6 (Portable) Beotime wall clock (hallway entrance) Beoremote X (poor man's Halo )
I guess the software for the BeoLab speakers is different than the ones I have - Beoplay and Beosound. Luckily the the only software my BeoLab speakers rely on is the Beosound Core. Just curious what the software update was for.
Which is why general statements about how much they have improved when it comes to software, and how rock solid their software now is will fall on deaf ears.
There is little evidence of an improved capability in software delivery. The big problem that hampered the Android BVs was solved by letting LG do most of the work. The B&O app has remained stagnant and extremely limited. The Balance has been out almost 8 months, and their communication of updating it for multi room almost as long. Which gives me no confidence that the Halo will get any of the meaningful added functionality that dealers have talked about in any reasonable time frame.
But if people want to repeat the notion about how their software capability has suddenly become very / pretty good, go right ahead I guess.
Jaffrey2230: I guess the software for the BeoLab speakers is different than the ones I have - Beoplay and Beosound. Luckily the the only software my BeoLab speakers rely on is the Beosound Core. Just curious what the software update was for.
