Hi guys,The turntable cover light on my 7700 hasn’t worked for ages so decided to change it, when i turned power on the light came on briefly followed by a clunking noise from back of unit and the light went out, i can take the bulb out and unit plays as normal so no fused blown, the bulb is ok also as I can repeat the process only to have same results! Any ideas
