Perhaps if you'd let us know what you need help with?
Hi Martin,
Thanks for responding.
I was hoping to find someone who could restore it for me.
It seems that the clutches for the balance, treble and bass are worn out. And only one of the big white plastic wheels is intact.
I switched the big white plastic wheel out from the radio side, after having set the stations, to the amp side, so I can confirm that everything works fine.
Thanks,
Robert
