Hi
I bought a white BM1200 which is so good looking.
I bought it as "functioning" but i had 13V dc on the output. I never attached speakers.I changed the 3000 uf output caps - , that didnt to it - now the dc is 18V meassured between pos. and ground on the speaker terminal.....
The dc powersupply is adjusted to 33V.
I didn't adjust the bias yet, it is about 6.6 mV.
Do I miss something - or is something wrong…?
Br Torben
Burned output stage is the most likely.Check the output stage transistors and the emitter resistors.
Martin, I followed your advice of checking the output transistor, they were all good - nice rca's.
I changed all capacitors in the power supply and oytput stage, also emitter resistors....all adjustment on the 33V voltage and 7,5 mV on emitters are good.
I still have 0 v ac, but 18,4 v dc on both outputs.....hmmmm. The same dc amount on both sides of the output caps.
The schematic is so that there is a 3000 uF at the end of each output stage - just before headphones/speakerterminals...…..
When I meassure with my multimeter for dc on the outputs with no speakers/headphones connected, isnt it so that I will meassure dc voltage "hold" by these output capacitors? And if speakers where connected, the dc "hold" would dissapear.due to 4-8 ohm circuit? Perhaps with a little Beomaster thumb at power on?
Shouldnt I be good and done repairing - ready for speakers? Im still a beginner in this…..
Solved….
DC offset (a lot) is normal for the construction due to the output caps.
I found this
https://audiokarma.org/forums/index.php?threads/bang-olufsen-beomaster-1000-dc-offset-problem.736246/
When speakers are connected there is no dc offset....
But I have no sound on left channel from tuner!From recordinput I have both channels.When "mono" is on I have sound in both channels from all sources.I resolderi everything on the tuner board - + the input switch board - that didnt make it.
Its connected with a not nice "thumb" changing input - especially from tuner to record/tape...
