M75 woofer replacement
This post has 1 Reply | 2 Followers
altamira
Posts 1
altamira Posted: Fri, Nov 20 2020 4:13 AM
My woofer has a slight rubbing in the voice coil.  It presents itself at higher volumes.  I am looking to replace it.  is there a woofer available that is a good replacement?
Saint Beogrowler
Saint Paul
Posts 780
I’d try to get it fixed. I found this on a M75 driver that had the foam replaced by an amateur. Found a used replacement driver but all the original driver needed was to have the foam released, properly shimmed and reglued.
Page 1 of 1 (2 items) | RSS
