Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
you can put the combined settings under a mybutton if you like
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
@Michael
If you are curious enough, you might read this excellent thread that KMA once made (for his BV11).
Loads of tips and hints there, when you want to tweak the sound of a modern Beovision.
https://archivedforum2.beoworld.org/forums/t/3372.aspx
When I press one of my Buttons, the TV turns to the corner and the sound settings calibrates to this.
Else the sound image would be bad.
One of the brilliant things with B&O
