Hi there,
I replaced my old Panasonic plasma with a LG C9.
It worked nicely for some minutes, but then I got a black screen. Switched back to the old tv, black screen. My Beosystem 3 9606 was gone. The diagnosis I received was a dead FPGA chip in the PCB5 board.
B&O support told me to trash my BS3, as no spare parts are available, but I managed to find a donor equipment that had a power supply problem (also no fix for it from B&O).
Not believing that the new TV caused the issue, as other devices connected to the same HDMI port shows no problem, I tried it again. Stupid! Now I have to find another PCB5 board...
I'd like to ask if anyone has successfuly connected a Beosystem 3 9606 to a LG C9, so that I can confirm that there is no software/firmware compatibility issue, increasing the chances of this beeing a hardware problem on my side...
Dante: I'd like to ask if anyone has successfuly connected a Beosystem 3 9606 to a LG C9, so that I can confirm that there is no software/firmware compatibility issue, increasing the chances of this beeing a hardware problem on my side...
For a few weeks connected a BS3mk3 (with hdmi outputs) in combination with a GX65'. BS3 has 2 PUC's. One for switching on the GX and 1 PUC for controlling. Works well, not flawless (sometimes panel stays off or keeps on when shutting off the BS3). All controlled by a BR1.
Hi Dante, sad to hear this. I do have a C9 55inch connected to a BS3 type 7710 for some months. No issues until now!
Johan: No issues until now!
Meant positive, or starting to have issues?
No issues at all :-)
The 7710 already has HDMI outputs, right?
My BS3 is MKI and has DVI-D outs, so I'm using an adapter.
I have Bsys3 mk3 (type 7711,latest model and software,with hdmi outs,3d etc) with Samsung 55'' uhd tv.More than 5 years trouble-free use.Time to change tv to LGGX .
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
