Hi All,
I got newly a beosound 5 Beomaster 5 and would like to connect his unit to the Bose 901 Speakers, as you may know there is a sort of equalizer for the bose, so it needs an output cable to connect to the input of the equalizer and from the equalizer it should go back to the beoaster. any help would be much appreciated.
I have also a beomaster 5500.
Thank you for your suggestions.
John
