Pairing Beoplay M3 ?
This post has 10 Replies | 2 Followers
CB
> You are Here <
Posts 1,762
CB Posted: Fri, Sep 7 2018 10:02 PM
Hi
It seems to be possible, but I failed pairing them with the Beoplay app.
Did you successfully did it?
And how, with which smartphone?
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Sep 8 2018 9:03 AM
CB:
Hi
You need to first make sure the M3 is on your network.
Installation guide here: https://youtu.be/eRERe3OaJUI
The app should then find the M3.
I used iPhone 7
CB
> You are Here <
Posts 1,762
CB replied on Sat, Sep 8 2018 2:22 PM
Thanks for the link Hiort, but this video does not explain how to pair M3s Sad
I can connect them via BT on my iPhone 5s or Samsung A5.
The Beoplay app find them on Android, not on iOS ?!?
On Android, both M3 are visible in the app, but there’s nothing to pair...
tph
Denmark
Posts 161
tph replied on Sat, Sep 8 2018 2:46 PM
Are you talking about pairing two M3s for stereo operation? Unfortunately that is not supported by the product.
— Tuomas | Bang & Olufsen | Bang & Olufsen Create
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi CB,
It is possible to manually cable two M3 speakers to get them to work with your phone as a stereo pair, even though this isn't supported for wireless pairing.  Please drop me a line via my sponsor link below if you would like more details of how to do this via a cable connection.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
CB
> You are Here <
Posts 1,762
CB replied on Sat, Sep 8 2018 9:40 PM
Thank you Tuomas, Steve and Hiort.
It’s not important, I was just trying to see how it works... or not Wink
Millemissen
Flensborg, Denmark
Posts 14,680
Sure - cables can make this possible.
But how would you control the individual (internal) volume of the M3’s?
I have tried this with two S3’s - it did not work out well (for my taste and expectations for ease of use).
I even made a second attempt a year or so after the first one - with the same result....sometimes one of the speaker was louder than the other
and regularly I had to adjust the volume on the speaker itself for balancing L/R channels.
The M3 (and the S3) is not a speaker - it is a small sound system, that is supposed to work on its own conditions....imo.
I’d love to hear of the results from other people trying this, though!
P.S. I have always wished that they would make a S3 version with regular PL-input port and a L/R switch 🙄
Posts 2,165
Hi MM,
Yes, when you first connect the speakers, you would need to adjust the two speakers to the same volume level, then you should be able to control the volume from the phone without any issues.
Steve.
Millemissen
Flensborg, Denmark
Posts 14,680
I ‘should’, yes - but the practice (at least in my case) was different.
Anyone tried? Please report back....
.....might give it a third try 😉
crossbytje
Posts 224
Sorry for the reply on an old post, but with the current stereopair announcement, this came on my radar.
Stereo pairing using the line-in on the M3's is easy with a cable like Steve suggests. You can fix the volume for the line-in source in the M3, so it is always the same as the other speaker. Actual volume adjustments are done in the source then.
Beolit 12 - Beolab 4 pc (dead now) - Beoplay H5 - Beolab 9 - BeoRemote One BT - Beoplay M3
Sarotti22
Posts 8
Sarotti22 replied on Thu, Nov 26 2020 7:05 PM
Hi, also excuse for the late Answer. Today I found the information on the B&O Website, that the Stereo Pairing for the M3 should be possible with the Google Home App. However it works. It seems to be a solution.
Page 1 of 1 (11 items) | RSS
