Hey guys, now that B&O is switching from ML to NL, do you think there's any point buying a BV-7 which uses ML technology. Also the same with BS 5?
gmittal: Hey guys, now that B&O is switching from ML to NL, do you think there's any point buying a BV-7 which uses ML technology. Also the same with BS 5?
there is already a converter box (with limitations) between ML/NL.
so I think the question is whether you are buying new kit from a dealer, or whether you have a really good offer from ebay or whereever
so I think you should be asking a value/price and longevity question.
and get to understand whether the current converter box meets your needs.
with B&O it is best to have a roadmap over time of planned purchases .... then you will be in a better position to make trade off decisions.
BeoNut since '75
