Hi - I am using a Quad 303 to drive Beovox M100 via a Blink Active kit. it works really well but I'd like to be able to switch the amp on via the Active.
I believe that pins 2 (ground) and 4 (supply on) give the 5v out - from there I can use a trigger circuit. Greatfiu if someone could confirm the pins that give the 5V out please?
