So this is actually a old problem for me. Initially when i bought it it wouldn't read cds at all. So i got the capasitor repari kit, and fixed that. But then i realised it only played 1 channel, the right one. No change if i moved the input to phono cables or to aux. And both channels work when putting the casettedeck in its place, if i recall me trying. Both channels on beomaster works fine. Any thought where to look, more capasitor need changing or?
Check inside the DIN plug for leads broken off.
i tested with phono cables also, same results.
