Beolab 50 Toe-in
wanc1
Posts 29
wanc1 Posted: Tue, Apr 27 2021 10:43 AM
Hi all,
I was wondering how much toe-in you have on the Beolab 50s to get the best sound. I can't seem to get my Beolab 50s to an optimal setup position.
AdamS
Posts 373
AdamS replied on Tue, Apr 27 2021 1:07 PM
Beolab 50s have built-in room equalisation. You don't need to worry about toe-in!
Mr 10Percent
So West, Its Now East
Posts 591
My BL90s are toe-in. I toe them into as near to an equilateral triangle (30 deg) to my optimal seating position with the primary treble array directly facing me.
Why with beam steering and Room correction?
My logic is I assume that getting the primary treble and lower treble array in as near as perfect alignment to my ears with minimum cone reflection off the walls will be "better".  I "assume", theoretically, that this will give the DSP and room correction features more hardware to deal with less reflections off the nearby walls (and one corner in particular).
My BL90s are 4m apart and 3.8m each from my head. Imaging is very good (wall directly behind my head). However, I once had an apartment lounge with a different layout where I had another 4m of space behind my head. This gave superior imaging. (Narrow and deep seems better to me than wide and shallow spaces).
I think you need to give more specifics as to why you cannot get the BL50s to an optimal position?
Are you having difficulty with image or tonal quality/sound balance?
Size of room, furnishings? If you live in a glass box, the DSP/RC can only go so far? Positioning of loudspeakers in rooms of AxBxC dimensions will still get nodes etc.. Again, the DSP/RC can only go so far. Its physics.
AdamS
Posts 373
AdamS replied on Tue, Apr 27 2021 9:30 PM
I should clarify, my BL90s are also toed in, purely because they look nicer like that!
wanc1
Posts 29
wanc1 replied on Wed, Apr 28 2021 2:14 AM
Thanks for the reply. I generally find that whenever I toe-in the speakers by around 20 degrees. From my listening position, the center image becomes really narrow, and by slightly tilting my head to one side, the entire image would shift completely. My room is around 8 x 6 m (wide and shallow I guess) and 3 hard walls and window glass behind the listening position. The speakers are also 4 meters apart and around 3.8 meters from the listening position.
MaxH
Posts 126
MaxH replied on Wed, Apr 28 2021 9:01 AM
I recently recalibrated my room compensation and found it made a difference to the narrow/wide ranges and also the bass.
This may be because of a software update or because of use or changing room furnishing but if you haven't recalibrated recently it makes sense to do so.
Although I always have my speakers toed in, something I have tried in the past and is also useful is to change the speaker distance until the central image is spot on and see if this has the desired effect.
For this I use Tom's Dinner by Suzanne Vega which gives a perfect central image.
Michael
Sweden
Posts 2,578
Michael replied on Wed, Apr 28 2021 10:39 AM
I have my speakers toed in as well but only a little. This is to focus the center of the tweeters peak to my optimal seating position.
I also want them to spread sound as wide as possible and for that they should be less or not at all toed in. But then I don’t find that the dome can send its sound optimally towards my couch.
There is suggestions also in the technical sound guide available on the B&O support page.
I remember also that Geoff replied, in his typical way, here some time ago that I’d you have friends then don’t toe in. I’d you don’t have them then toe in :).
Regarding software me myself find that the sound profile is very tame in wide mode so I prefer narrow nowadays. I believe they did something with the software and am still a bit annoyed about it but I guess it is as it should :).
I have the microphone as well (and was equally annoyed having to pay extra for it when it is referenced as included in the manual).
Page 1 of 1 (7 items) | RSS
