Hi All
One of my old MK 1 Beolab 4000 speakers is a bit sick.
Have a loud buzzing noise and crackling noise when turning up and down the volume.
Took the speaker apart and swapped some parts from a working speaker and found the amplifier board is the problem. So my question, do you guys know a dealer preferably in Denmark who are willing to sell parts and not only willing if the do the repair them self. My local B&O dealer wont.
I fix these (thoroughly with overhauling/replacing several parts for reliable future use).
If have several boards in stock, which can be swapped when boards arrive.
Hello Beobuddy how much do you ask for an mk1 board? Or wich components are needed to replaced?
