Hi
I am trying to set up a gateway ? and i did think that it is backwards compatible to legacy products ?
I have looked for drivers for the legacy products but can not find any .
The set up in my home is Beovision 11 in the Snug , Eclipes Main room also Beomaster 5, Bevoision 6 kitchen and Bedroom both Beovision 6 are the Hdmi models.
Can and body give my help with direct of set up , I have tryed doing a hard reset on gateway but it refuses to do a hard reset for factor reset and password .
I can log on to the Gateway and see it on my network , I just wanted to use it for some outside cameras and for the App and easy of use on iPad for Bombaster 5.
Any help would be helpful
