Hello everyone, can you help me with the Netflix app on the from BV eclipse? When I use the app the 5.1 sound is always very quiet. If I switch to stereo sound I have a normal volume again. all other sources work perfectly. Do I have a wrong setting here, or is this completely normal?
Thank you!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
In setting for the source (Netflix), there is a dB setting that can normalise sound levels between different sources. My Eclipse plays Netflix loud and needs scaling down.
