Hello to everybody,
can anybody describe me how to start a CD in a Beocenter AV5 (which is in a linkroom) from the mainroom?
Thank´s and regards ...
Patrick
Wohnzimmer: Beovision 4-42 auf umgebautem Gehäuse von BV Avant 28 & Beosystem 2, 3x Beolink Passive 1656, Beolab 4000 (Front), BV Avant LS im Gehäuse (Center, an Beolink Passive), aus BV Avant 32 entnommene LS (rear, an BL Passive), zu subwoofern modifizierte Beovox S80-2 (nur Bässe d an BL Passive). LC2
Schlafzimmer: Beovision 8-32 und Beomaster 4500 (zusammen auf modifiziertem Stand von BV MX 4000) mit Masterlink-Konverter 1411, LC2
Bad: Beolab 3500
patriccho1971:Hello to everybody, can anybody describe me how to start a CD in a Beocenter AV5 (which is in a linkroom) from the mainroom? Thank´s and regards ... Patrick
thats is not possible.. you can NOT connect to sources in Linkroom! only sources from mainroom then you are in linkroom
Beouser66:Hi, thats is not possible.. you can NOT connect to sources in Linkroom! only sources from mainroom then you are in linkroom
