I've plugged the beomaster 3400 and it work well!
The only problem is with the main tuner: tunning works perfectly one side (from 104 to 89) but has hard time the other side (from 89 to 104) like maybe 4-5 turns to go up the whole scale but 5-10 turns to go down one vertical bar only.
After opening it I can see the cord is slipping one way and not the other. The string looks like tight. Can't manage to figure out where the resting point is, everything spin smoothly, but the dialing is reluctant still.
I havent counted the number of loops around the tuner pulley (the electric one) but I dont believe there is enough cord to add a full turn.
Any advice would be welcome.
Thanks.
