Beoplay A2 Charging Issues
Richardson45
Posts 1
Richardson45 Posted: Sat, Jun 6 2020 2:49 PM
Wonder if someone can help.  I have had my A2 for a few years, it has had minimal use and I last used it about 4 months ago and now the weather is improving I wanted to use it for outside in the garden.  I plugged it into charge, left it overnight and it hasn't charged.  The charging light is flashing orange on and off and when I try to power it up the light goes on, but then goes straight off again.  So it feels like it is maybe the battery?
Could it be that due to lack of use the battery has drained so much it simply can't re-charge itself, or maybe the charging cable is faulty, although there is clearly power getting to the unit, as I imagine it wouldn't flash if it wasn't.
Thank you so much.
MarcosAlvarenga
Posts 33
Same problem here. Have you figured it out?
Page 1 of 1 (2 items) | RSS
