Hi and a Merry Christmas to you all.
I got my 6-22 for a steal, haven’t used it much since the analog network was shut down here in Sweden. I’ve attached photos on the little decoder (?) that was included. My question is, how do I connect an Apple TV or chromecast, and what settings need to be done in the settings menu etc on my tv?
Thanks guys!
You'll need one of these and the red, white and yellow cables.
That will then connect the "adapter" to a SCART socket on the TV.
Are you able to tell us which buttons your remote has. Mine is TV DVD DTV & V.MEM. Some are TV DVD SAT & V.TAPE. This will help us to help you sort out connections in the TV Menu.
The "adapter" will need a power source, and then the AppleTV or Chrome cast will be plugged in via HDMI.
Stoobie
I’m having trouble understanding you. Do I need the adapter you posted plus the box I already have? I can’t see no HDMI input on the one you suggested as well. How do I connect it all? Thanks for your help
Sorry, pressed the post button too soon. See update post. You will need that adapter too unless the TV has the red, white and yellow sockets on the back..
I used this one for a BC6-26. Picture connected to YPbPr, sound to R/L analoge. But these connections are not available on all BV6.
"HDMI to Component YPbPr Scaler 1080P, PORTTA Adapter Converter HDMI naar RGB Video + R/L Analoge audio-uitgang 720p 1080p voor PS2 PS3 STB Xbox360 DVD HDTV Projector Monitor - Scaler"
text copied from Amazon
