Hi All
I have bought a Beomaster 901 and would like to be able to connect the following:
1 A NAD record player with external RIIA
2 A NAD CD player
3 A Bluetooth device
I have seen that through different cables, I'm able to connect the record player and the CD - but then there's no more ports on the back.
Is it possible to have the 3 parts connected at the same time?
You will need a DIN 5 pin splitter cable like this one:
Køb 5P DIN / 2 x 5P DIN hun Splitter kabel - 0.2 m på Av-Cables.dk (av-cables.dk)
-then you can have 2 devices to one port in the receiver. But they are (offcourse) DIN plugs -so you'll also need some extra phono-DIN adapters.
Unless your turntable is far off standard, you will not need an external RIAA.The rest can be done with a normal line-level switch connected to the Tape input.
