Eclipse speaker settings
This post has 9 Replies | 0 Followers
stuart50_1
Posts 65
stuart50_1 Posted: Fri, Jan 1 2021 2:37 PM
Hi
Happy new year
I have a beolab 2 connect to the eclipse but it does not turn on ?
Its set up in speaker roles /speaker levels but when I come out of the setting and watch tv the sub turns off ?
any idea please
Ingo
Da wo die Weser einen großen Bogen macht
Posts 147
Ingo replied on Fri, Jan 1 2021 3:44 PM
Happy new  year,
do you use the speaker Connection?
Sorry my dumping question, only an idea, because the connection board has two rows of connections, one for the PUC connections and Mic, the other for the Beolabs, please make sure, otherwise set up as described in the operating instructions.
CU
Ingo
BeoVision Eclipse 55“ wallmounted, BeoRemote One BT; BeoSound 9000(ex-weiss), BeoLab 9; BeoLab 8000 rot; Beosound 1 grün; BeoPlay H6; Beo4
Ingo
Posts 147
Ingo replied on Fri, Jan 1 2021 3:45 PM
stuart50_1
Posts 65
When I use the speaker roles set up,I can hear the beolab 2 so I am sure they are connect properly.
Ingo
Posts 147
Ingo replied on Fri, Jan 1 2021 4:04 PM
O. K.
The manual says:
 Disconnect all systems from the mains before you connect additional products.
Mikipidia
Posts 2,169
Then it’s not configure in your speaker preset to be the sub or to be on.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Ingo
Posts 147
Ingo replied on Fri, Jan 1 2021 4:08 PM
The Illustration in the manual shows an example of a speaker setup with two front speakers, two daisy-chained rear speakers and a subwoofer.
Can you choose the Beolab 2 in the Setup?
stuart50_1
Posts 65
Yes and I can her it
Mikipidia
Posts 2,169
Go to the speaker preset menu where you can set the roles of your speakers and set the bl2 to on as subwoofer. It’s mostlikely not switched on in the preset you’re using(start up)
andybandy
Posts 164
andybandy replied on Sat, Jan 2 2021 12:26 AM
Do you have other speaker Connect to eclipse? Or only tv speaker and beolab 2?
Page 1 of 1 (10 items) | RSS
