Beocord 9000 Issues (Maybe stuck in Cal?)
This post has 6 Replies | 0 Followers
aroomwithaview
Posts 16
aroomwithaview Posted: Sat, May 2 2020 6:29 PM
Hello!
Recently purchased a Beogram CDX, Beogram 8002 (w/mint mmc2), Beocord 9000, Beomaster 6000, and 2 RL140 speakers for 300USD. Came with all original manuals, service records, cables, calibration equipment etc.! I think it was a steal considering, the Beogram CDX, 8002, and speakers work perfect.  Having trouble with the BM6000 and BC9000.
So I exchanged all the belts and rubber parts to the BC9000, but it really won't do anything.  See video...this is all i could get it to do. Just blinks = and backwards C back and forth.  I took the fuse out and it operates the same way, so I am thinking the fuse is bad, but it doesn't look blown at all....Could this be a fuse problem? Any other ideas of anything else?
Thanks so much!!
https://www.youtube.com/watch?v=os3mihwlBKc
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, May 2 2020 6:45 PM
Is the motor running?
Is the capstan running?
Does the tapeheads engage, when you press play?
aroomwithaview
Posts 16
Motor and Capstan running smooth.  When I press play the first time after turning on, the heads engage for a second then go back down.  Can't get them to engage again with the play button until i turn on standby or unplug and press play again, and it does the same thing.  If i hold memo go, the head will pop up and down and up and down continuously.
Thanks for the reply Martin!
Dillen
Posts 13,191
Dillen replied on Sat, May 2 2020 7:04 PM
Well, the vast majority of these decks will be in need of a thorough service by now - after 30-35 years.
Not uncommon for any tapedeck - or any other piece of electronics, really.
But -
Check for cracked solder joints where the large connector from the tape drive goes to the board at the bottom of the Beocord - under the motor - accessible by removing the Beocords bottom plate.
Check also where the long cable from the tape drive goes to the display board - accessible with the Beocord in service position.
aroomwithaview
Posts 16
Will do, thank you Martin!
aroomwithaview
Posts 16
Nothing I can see here, no cracked solder joints, or nothing amiss. Ill take it in somewhere I guess, thanks!
chilibt
Posts 5
chilibt replied on Thu, Jan 7 2021 10:01 PM
I have a Beocord 9000 which will not stop CAL session after the stated 9 seconds or so.
The tone is on two channels and I have tried several different tapes, 2x Cr and one Fe,  without a change to the constant CAL.
I am wondering if the built in Li battery may be an issue or perhaps something else.
Terry
Page 1 of 1 (7 items) | RSS
