Has anyone successfully integrated a B&O product like a Beovision TV without a MasterLink/BeoLink gateway to be able to control them with a Beo4 or BeoRemote One, as well as control the TV from other products?
I've got all I need for this to work, except the software. The Beovision 11, my Hue lights and other stuff are all on the same network. It should be possible to emulate a MasterLink/BeoLink gateway using Home Assistant or some other Linux application on, for example, a Raspberry Pi. B&O's own hardware works very well, but it's expensive and seems pretty unnecessary now that the smart home tech has gone mainstream and become cheap.
Since the TV can be controlled by an app, it should be possible to use those commands in Home Assistant too, to control it and make automations.
Has this been done?
Yes there is an integration here: https://github.com/giachello/ha-beoplay
I am planning to rewrite it because it's a bit buggy, but it works well enough.
Giovanni
giac:I am planning to rewrite it because it's a bit buggy, but it works well enough.
Hi Giovanni - There is no Issues tab in the ha-beoplay Github project, how should I share questions, issues or request for enhancement?
