Experience with scratch removal / polishing of Beolab 8000?
MVee
Posts 6
MVee Posted: Thu, Jan 7 2021 12:22 PM
Hi all,
Does anybody of you have experience with polishing the aluminium tubes, removing more severe oxidation/scratches and getting them fully shiny again?
I used various grains of polish on stainless steel of my espresso machine to get it prefect again, but wonder how the materialization of the Beolab is and if I would be able to polish out rather significant scratches on that aluminum as well.
Looking forward to your experiences and tips&tricks. Thanks a lot!
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Don't do it!!
They are anodised and any use of abrasive will remove the anodised layer and it will stick out like a sore thumb.
Regards Graham
Page 1 of 1 (2 items) | RSS
