I have a beovision 3. I have successfully loaded up my n64 via the panel on the front of the tv with the composite cables but I find the graphics terrible and not what I remember for an n64.
I then tried to play the n64 through the scart AV socket at the back of the tv with the composite cable plugged into a ‘Xbox’ scart adaptor but I can’t seem to get any pictures loading up
Could some one help me understand why? Do I have to assign? Is it that it will not work as the n64 is not rgb? Or is it that the ‘Xbox’ scart adaptor does not work?
thank Im advance.
Anyone?
thanks in advance
You may want to change your title to "Need help connecting N64 to Beovison 3". Especially as it is an older TV.
You don’t say if it a Beovision 3-28 or 3-32. They may have different connections/inputs and this will assist people trying to help. It will also assist to know what you have already got cnnected to the TV and what buttons are on your remote. Is it a Beolink 1000 remote or Beo4? We need to know what buttons to assist in the connection menu. In the top 9 buttons the Beo4 may say SAT, V.TAPE & A.TAPE or DTV, V.MEM & A.MEM.
As you say there may be various problems, but as it works using the front connections It should work from a SCART. You do need to “assign” B&O TV inputs work differently to most TVs. You have to choose an input and assign a button on the Beo4/ BL 1000. The inputs are also setup for different components to be connected. On most older B&O TVs the SCART marked V.Tape is for a B&O Video recorder (or HDD1/DVD1). So plugging your adapter in there may not work.
There may be a SCART marked AV. This input may be your best bet. There may also be one marked Decoder (Depending on TV Model). But it is worth trying all inputs
When connected you need to go into the onscreen MENU and go to the connections MENU. The connections may already have something assigned or say NONE. Go to the AV input. and scroll down to find either SAT or V.TAPE. and save. Now when you press SAT or V.TAPE (depending on what you chose) on your BEO4 it should open the input. Do the same for each input you try.
Finally, if that does not work, Itmay be the XBOX adaper that is fulty.
Good luck
Stoobie
The User Manuals are availble on here if are a Silver or gold member.
Hi Stoobie
Thanks for the tips and information:
Its a beovision 3-32
Beo 4 remote: buttons are from top left:
TV LIGHT RADIO
SAT DVD CD
VTAPE RECORD ATAPE
i will try your method again as i did assign but was not sure what to assign it to
Many thanks for your help
I forgot to ask if you have anything else connected? If you have nothing else connected, you have free range of buttons to choose when setting up. I would connect to the SCART labled AV. Go into the menu and go to the AV inpiut and make it SAT or DVD then save. When you want to see it on screen you press SAT or DVD (depending which you chose) on the remote and it goes directly to that input. The inputs are selectable by the button you tell it in the setup menu.If you have other stuff connected, tell us which socket it is connected to and what button on the remote is allocated in the setup menu. There are also further "soft buttons" available to be added to the screen of the beo4 if you need it.
