Beocenter 2 and Beo 4 remote control.
This post has 9 Replies | 0 Followers
Garyy
Posts 4
Garyy Posted: Sun, Sep 4 2016 1:09 PM
hello,
i have recently bought a Beocenter 2 and it works fine when using the buttons on the front, however the remote control doesn't work at all.  The remote works fine on my A8 speakers so it is working.
do I need to pair the beo4 remote and Beocenter 2 In some way.  Is this a massive issue and I should return the equipment?
Many thanks
Gary
Millemissen
Flensborg, Denmark
Posts 14,680
Hi and welcome to Beoworld.
Your BC2 probably is set to Option 0 - did you check that?
Garyy
Posts 4
Garyy replied on Sun, Sep 4 2016 7:20 PM
I haven't tried that. Not sure where to find it.
 Is it in list then options?
many thanks for the help.
Gary
Millemissen
Flensborg, Denmark
Posts 14,680
You can find instructions about howto in the user guide for the socket unit (page 10).
Look for it on the B&O homepage.
Rob - Danish AV
Melbourne
Posts 376
If you went to the effort to tell him the page number, you probably could have copied the text and paste it here, make a new user feel more welcome
From memory, the unit needs to be in standby, you need to press list and the power button on the Beo4 until the text says add?  arrow down to option? Press go and arrow down to a.opt then press 1. The standby light on the BC2 should flash.
Millemissen
Flensborg, Denmark
Posts 14,680
Rob.B:
Please don't worry!
I did this on purpose - what can be more 'welcoming' than to help a new user help himself?
David Coyne
Sydney, NSW, Australia
Posts 305
Big SmileBig SmileStick out tongue
Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Rob.B:
Very inappropriate comment.  In the majority of cases, newbies come here seeking help, receive it from several members, then forever disappear without even saying 'thank-you'.
Well-handled reply MM.
Garyy
Posts 4
Garyy replied on Mon, Sep 5 2016 12:44 PM
Many thanks for this information. It seems to have done the trick and I have it working properly now.
The B&O shop recommend that I bought it all in for a repair !
Gary
hugosnel
Posts 16
hugosnel replied on Mon, Feb 1 2021 11:49 AM
Hello,
I am having a connection problem with normal B&O Audio Terminal
That is the universal remote from B&O, the long one.
Please help!
Page 1 of 1 (10 items) | RSS
