Eclipse -- central channel question
This post has 13 Replies | 0 Followers
mseverg68
Milano
Posts 53
mseverg68 Posted: Wed, Jan 20 2021 5:06 PM
Hi everyone,
i have an a question. In a 5.1 set up with BL17 as front, BL11 sub, and  BL6002 as surround, the correct setting of the center channel on Eclipse is:  Eclipse-C center front active  and Eclipse-L and Eclipse_R disactive,  or  C-L-R set all center front active ?
Many thanks
Seanie_230
UK
Posts 2,278
I have all of mine set as centre and have fronts also.
There is a post from Geoff about how to set this up.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mseverg68
Milano
Posts 53
mseverg68 replied on Wed, Jan 20 2021 6:24 PM
but with that set up the 'Output channel allocation' is 7.1
Is this correct?
Seanie_230
UK
Posts 2,278
It is but it’s actually 5.1 but says 7 because you have three channels doing centre
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Wed, Jan 20 2021 6:42 PM
No that is not 7.1. You only have 3 center speakers instead of one. The center will be more powerful than with only 1 center. You might experience a bit of odd sound experience as the center is a bit wide. Geoff explained in the video of Henrik of B&O Technik Forum on youtube how you can set up the three speakers in Eclipse in combination with speakers LF and RF, LR and RR.
To have 7.1 you need surround hight speakers. Also be aware that your BL11 is not too powerful and will not give you the full theater experience, therefore you”ll need a BL2/19/14sub.
My guess is the bass management on Eclipse will send the bass to BL17 instead of BL11.
Fansastic
Posts 768
Fansastic replied on Wed, Jan 20 2021 6:43 PM
Seanie_230:
It is but it’s actually 5.1 but says 7 because you have three channels doing centre Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
If setup as center speakers (3x) in Eclipse it will not say 7.1., just counts as 1 speaker
Fansastic
Posts 768
Fansastic replied on Wed, Jan 20 2021 6:56 PM
I stand corrected: the sound info on Eclipse will say 7.1 output indeed. But it is not a 7.1 setup. The true image processor is sending the center channel to the three speakers in the Eclipse
Seanie_230
UK
Posts 2,278
Fansastic:
I stand corrected: the sound info on Eclipse will say 7.1 output indeed. But it is not a 7.1 setup. The true image processor is sending the center channel to the three speakers in the Eclipse BV Eclipse 55 Brass - BL 18 Brass - BL 19 Brass - BL17 Black - BL 3 White - BS Moment - BS 2 Brass - BV Horizon 48 - BS3000 - BS 3200 - BS Essence MK2 - BL 4000 - V1 40 Black - V1 40 White - BLC NL/ML - H6 - H4 - E8 Motion - A8 Earphone - Beolit 12 - Beolit 15 - Beoplay A1 Green - Beoplay A3 White
Yeah it quotes the three channels as separate.
I have my sound setup as Geoff said and it’s excellent.
I think from memory it was to have all three set to centre but middle one set about 0.2 meters further than the outer to get the middle first.
Decibels are also changed I think middle is +1.5 and outer centres are -1.0
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Michael
Sweden
Posts 2,578
Michael replied on Wed, Jan 20 2021 10:19 PM
Seanie_230:
There is a post from Geoff about how to set this up. Eclipse 65 V1-32 Beosound M5 Essence MK2 BLI
I think Geoff would recommend not to do that as it would introduce different delays in the sound and less optimal for dialogue. But I don’t remember where I might have read or heard it now.
But I believe the center should always be just the center. Right and left should be off.
Millemissen
Flensborg, Denmark
Posts 14,680
Watch this:
https://youtu.be/svIUxzKzI8E
Start at 14.30......or watch from the start ;-)
mseverg68
Milano
Posts 53
mseverg68 replied on Thu, Jan 21 2021 10:08 AM
Many thanks ,but I am a bit confused.
So what seems to be the best solution to set the central channel ?
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Jan 21 2021 12:15 PM
Define best? Either of these options are great if they work in your room and you like the sound of it. I personally don’t like it as much, so it’s just another speaker group for me.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
mseverg68
Milano
Posts 53
mseverg68 replied on Thu, Jan 21 2021 12:29 PM
So how did you set up your center channel ?
Mikipidia
Posts 2,169
Mikipidia replied on Thu, Jan 21 2021 12:32 PM
Both ways, but my default is just the center stack of speakers on as center.
Page 1 of 1 (14 items) | RSS
