I have just put an order on the Beoremote Halo with tablestand.
Does anyone know the "roadmap" of the coming software updates and which features that wll be added?
Best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hi, does anyone know if you can change volume on the Beolab 50 directly when you have an external streaming device connected directly to the Beolab 50?
The Halo is using wifi and the that should be possible when the labs 50 also is using wifi.
Maybe Mikipedi knows this!
Indeed it certainly not possible with the Helo.
Amazing huh?
t Martin: Hi, does anyone know if you can change volume on the Beolab 50 directly when you have an external streaming device connected directly to the Beolab 50? The Halo is using wifi and the that should be possible when the labs 50 also is using wifi. Maybe Mikipedi knows this! Best regards Martin
Doesn't work as of today, is technically possible, I am unsure if it'll be in the next big update. From what I gather they're looking at it, but I don't know what that means as of yet.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Miki,
do you know the date for the « next big update »? Spring? Summer?
Hi, It seems that I can not save a Favorit from Deezer with my Halo. Is it a sw bug when using it with Eclipse V1?
Does this function , saving favorites, work as it should with Beovision TVs (eclipse/harmony)?
Could this mean that the BR One can now save Deezer playlists as well?
Hi, I have found out that I can store different "sources" with the four favorite buttons but not a specific playlist from Deezer and not a specific radiochannel from Tunein.
When using the Eclipse I can store Music, TuneIn, Live TV, connected Apple TV and so on.
When using my Beoplay A6 I can store Music and Deezer and TuneIn.
I can not store a specific radiochannel, or a specific playlist or album with the four favorite buttons with the Halo.
Does the Harmony/Eclipse V2 have a more sofisticated software so you can store a specific playlist or a specific radiochannel with the Beoremote Halo?
Best Regards
