Hi All,
Just want to ask you a few questions -
Does anyone know when Beolab 2 stopped production?
Did it have any major updates during it's production run, if so when?
Also, regarding the issue with sticky plastics on the early Beolab 2 drivers is it happening alot? just that I've come across an early manufactured Belab 2 and all the speaker driver plastics have gone sticky.
Thanks guys.
Looks like all the plastics will go sticky, I've seen quite a few recently and all of them are slowly going sticky.
I've heard Beolab 3 are going the same.
Common thing now, the sticky touch...
You can strip the drivers and surrounds off, use solvent and a lot of time to strip them back, sand them down with very fine paper, mask them up then spray with automotive paint - but it takes ages and it's very messy.
Lee
