Hi. I have a Beogram 6000 record deck which has developed a slight problem. When the tone arm reaches the end of the record or you press stop mid play, the carriage traverses immediately before the tone arm has had chance to raise. The tone arm raises & lowers normally when the manual raise/lower button is pressed.
Is there an adjustment to delay the traverse to give the tone arm a chance to raise ?
Thanks for your help
