Putting A9 in the sun...
NickPG
Posts 25
NickPG Posted: Thu, Nov 5 2020 3:58 PM
Hi all,
Looking at adding the LG CX / Stage / Stand combo to my setup but it would mean moving my A9.
The easiest place, without wallmounting, is on the landing but this would be next to a floor-to-ceiling glass window which is south facing. Has anyone had any issue with sun-damage with the A9 in direct sun?
Thanks,
Nick
Beoplay A9 MkII, BeoLab 4000, BeoSound Essence MkII
Iceman10245
Berlin - Germany Nova Santa Ponsa-Islas Baleares
Posts 186
I have my A9 at the window in Mallorca and no problems. However, mine has this plastic cracking noises that bothers me and sometimes scare me
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass,  BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence ,  BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white,   Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
deltacafe
Posts 6
deltacafe replied on Fri, Nov 12 2021 5:17 PM
I have a very similar issue. I would like to buy an A9 but the best place for this appears to be next to south facing glass doors: Mediterranean sunshine.
Did you move it into the sunshine? Any issues / UV damage?
https://archivedforum2.beoworld.org/forums/p/18331/198742.aspx#198742
Known issue for 8 years that B&O hasn't fixed.  Putting it in the sun will make it pop and click more. Can't tell you about sun damage, if anything the white model MIGHT as well as the fabric.
BeoLab 18's. Beolab 3's. A8. A9. A2. H7.
deltacafe
Posts 6
deltacafe replied on Sun, Nov 14 2021 1:39 PM
Thanks for the pointer - that’s a valuable thread.
I think the info I’ll draw from this all is that direct hot sunlight is probably a bad idea! I’ve found an alternative in the Level, which also has the benefit of not being overkill in my small apartment…
Cheers!
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
