Dear all,
my old BL3500 is refurbished with new speakers :-) but unfortunely there is a unpleasant noise on the rigth side of the BL3500 :-( there is, between the tweeter and the display, a kind of opening or vent (see the picture). If there are basses in a certain frequency the BL3500 is clattering at this point.
What is the reason therefore and what can i do?
Best regards
Michael
Well,
now i can enclose this "old" problem:
Configuration: BM4500 connected to BL3500 via MCL (Master control link).
- when it's playing a very deep bass from any source, no problems at the NORMAL passive speakers (BeoVox4500 and Cona)
- same song with the same bass, strange clattering at the BL3500
- the clattering noise is coming from he tweeters!!!!
- the BL3500 is in a refurbished perfect condition,if i conect it via Masterlink to a BS4, there are no problems
Maybe there is a problem with the with the MCL connection (Cable?) or a problem with the BM4500.
Is this a problem with a pre-amplifier or the MCL system in the BM4500?
Thanks in advance!
double post...
