The products look interesting but they never respond to emails.
It lacks seriousness...
Hi Silou, we have sold some of Almando products and our customers are very satisfied with their products.
If you have questions, I can answer them here quickly
Designed-AV: If you have questions, I can answer them here quickly
Thanks for your answer. But it's a pity that Almando doesn't answer because their product are (too) expensive; for the same price you get a full A/V amplifier!!!
Question:
- Does it works: sound from Samsung Frame into the Toslink input (I canot use HDMI because there is 4 HDMI inputs on TV). By this way the sound of all 4 inputs should be 5.1 on the speaker. Right ?
- an HDD can be connected on the USB connector. Probably we can listen music from this HDD (which format are supported) How to navigate into the HDD music library ?
Rolf 2:Oneremote reacted very quick. I now use their Powerlink switches.
I'm glad that worked for you. I bought a PowerLink Aux Expander from OneRemote but it never arrived. When I eventually emailed them asking for status they said there was a mistake and the product was out of stock for another 6 weeks. About 8 weeks later I inqired again but got no response, and ahve had no response to 3 subsequent emails.
I understand that OneRemote is a small company but it's pretty disappointing to pay for something, not receive it, and have no response to email either.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
[DUPLICATE]
