Hi experts
I have a setup where i use an old beocenter 1 (V.OPT 1) for:1. CD2. Radio3. V.AUX (Chromecast Audio)
This is linked together with a Beomaster/sound 5 (A.OPT 0) for:4. N.Radio5. N. Music6. A.AUX (Not active now)
To distribute ML a beolink wireless 1 is added as transmitter.
My problem is, that if I e.g. start "N.radio" and vant to change to V.AUX, the N.radio does not stop but both sources play? It is the same with the other sources. If I switch between a source from the Beocenter to a source from the beomaster (or visa versa) the first source is not stopped.What am I doing wrong?
Thanks in advance for you input.
