Hi All,
Need some help from forumers here. Lately, I am hearing static/crackling noises on my Beolab 3 left channel.
I have tried narrowing down the cause of the static noise by A/Bing speaker and power cables, swapping left and right channels, detaching my Beolab 3 from my Beolab 11 and I have finally concluded that the problem is coming the Beolab 11 sub.
Question, does anyone know what might be the issue? This seems to only happen on the left channel. I am currently using them as a set of near field speakers for my desktop PC, therefore the static/crackling hum is rather annoying to me at such close distance.
Are there any past experiences with the Beolab 11 you are able to share, and what would be the next step of recommendation if you are in my position?
Cheers.
