I have BS9000 MK3 serial 189... with SW 3.4
with strange problem ..
Red led is flashing...unit is working for 3 minute than go off.
and i can perform test modes with no problem 71,73,74, 27 ,,ok maybe some cd issue some times ..but in general is all working.
When i enter PIN number on display shows ERROR . but the code is correct.
I can not find or do Master code input ( i have master code ) .
But red led is blinking all the time :( when in st.by or working.
strange...
any idea what could be wrong ?
Hi
I trade that unit for some BL 6000 speakers.
it's all MK3 not mix mk1,2 and 3. I did check all components.
Are you sure it's Microprocessor board ?
If i do test for Microprocessor all is ok no error ..hmmm
Based on what you have said it sounds like the pin code has not been accepted or written into memory.
How exactly did you enter the pin code? It should be entered by doing the following:-
Regards Keith....
All ok...solved...with master pin; )
