Beovison Eclipse - Music stream ?
Dyssegaard
Copenhagen, Denmark
Posts 263
Dyssegaard Posted: Mon, Feb 8 2021 3:49 PM
In the Sound Settings menu on my Eclipse 1st gen, under the sub menu Sources, there is a source named Music stream.
What is the purpose and functionality of Music stream?
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Feb 9 2021 5:25 PM
Dyssegaard:
In the Sound Settings menu on my Eclipse 1st gen, under the sub menu Sources, there is a source named Music stream. What is the purpose and functionality of Music stream?
It is in a way comparable with CC and/or Airplay, but the source is a UPnP/DLNA stream.
So if you use Audirvana, Brio, Foobar (with the right plug-ins)  and others you can stream Music directly to your Eclipse (up to 192kHz, 24 bit). If you do so you will get the source "Music Stream".
This is the same for other devices.
Dyssegaard
Copenhagen, Denmark
Posts 263
Carolpa:
Many thanks for your answer - much appreciated Smile
Page 1 of 1 (3 items) | RSS
