Beosystem 5500 with Beovision 7 and Beolab 3500 connected with Beolink converter 1611
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Oct 15 2014 1:20 PM
Hi.
I have the following setup:
Livingroom: Beosystem 5500 (connected to Beolink converter 1611 via aux/tape.2) and a Beovision 7 (connected with masterlink)
Bedroom: Beolab 3500 (connected with master link)
All masterlink cables goes into a master link junction box (the one with audio, video, link1, link2, link3, and link4)
My problem: I cannot turn on the BM5500 from the bedroom via the BL3500.
I am almost 100% sure that I have had this working before (in the summer I had the BL3500 on the balcony, and I was able to turn on the BG5005, BGCD5500, and aux -input from the balcony.
I have tried all option-settings I can think of, but I am having no luck.
Is there anyone that know how to solve this?
Best regards,
Leo
Millemissen
Flensborg, Denmark
Posts 14,680
Tried to unplug everything (also from the mains) - and replug it again?
Be sure to connect the converter (to the mains) as the last thing.
leosgonewild
Helsinki, Finland
Posts 2,373
I have tried, no luck.
What options should I put the different devices in?
leosgonewild
Helsinki, Finland
Posts 2,373
I got it working.
I put the Beomaster in option 5 :)
The Beomaster can only be put in option 1,2,5, and 6.
What is the difference between these options?
Millemissen
Flensborg, Denmark
Posts 14,680
Option 0 = Ingen IR-modtagelse
Option 1 = To IR-modtagere i samme hovedrum
Option 2 = En IR-modtager i hovedrum
Option 4 = Linkrums produkt forbundet til et eller to hovedrums-
produkter i samme rum
Option 5 = To IR-modtagere i samme linkrum
Option 6 = En IR-modtager i linkrummet
Sorry - only in danish, but I guess you understand the meaning of it.
JamesSamuel
Netherlands
Posts 51
Did you work this out? I have the same setup beomaster 5500, beovision 10 and beolab 3500 in bedroom. They also go in the same splitter..
i can turn on the beomaster radio, enz. But not the dtv and tv..
Page 1 of 1 (6 items) | RSS
